How to get rid of the error “Object reference not set to an instance of an object†when starting Workbench Meshing?
March 17, 2023 at 9:01 amFAQParticipant
When trying to start ANSYS Meshing, the following error occurs: “Object reference not set to an instance of an object†This error can be fixed by renaming (or deleting) all version folders in the following location in AppData. C:Users’user name’appdataRoamingAnsys’version folder’ E. g.: If you have installed Ansys R 19.1, R 19.2 and R 2019 R1, delete the folders “v191â€, “v192†and “v193â€. Keywords: Workbench, Meshing, start-up error
- Q: How do I set the license server from my client machine?
- Failover feature ‘Discovery – Level 1’ is not available
- How do I configure RSM to send a solve to a remote machine (no scheduler)?
